New Slider...
Gru
New Slider...
Post by Gru »
Ok, so the idea of slamming a GT-R into a wall isn't so hot.
In fact, shredding the paint every time I blow a tire isn't so great, either.
So got myself a full-time track car that I can toss and the walls and not mind if I rub....
Project Domestic Drifter is a go!
UPDATED: 4-16-08
PLANS
Immediate:
unfuck motor issues -- DONE
Check if rear brake shoes are also new -- DONE
unfuck e-brake cable -- Half done. Right side still fucked
Gut & FD-spec cage -- Gutted & at Izzy's!
Coil-overs -- Done! (just need to adjust rear ride height)
F & R lower control arms -- Rears done, Fronts awaiting K-member install
K-member -- Sitting in basement, waiting for car to come back.
"Bump steer" tie rods -- Awaiting K-member install (will be SN95 front spindles)
subframe rails -- DONE
torquearm brace -- DONE
watts-link -- DONE
(then remove rear upper control arms, since those are what bind all the time & won't need them with watts-link & torquearm) -- DONE
pop-off steering wheel -- DONE
racing seat w/ 4-point harness --BOUGHT, RAILS NEED MODIFYING TO FIT. (but now have plate steel to make adapters) But the Harnesses are in.
Intermediate:
paint & graphics for "The Black Pearl" drift pirate theme
5-lug conversion w/ rear disc brakes (& upgraded front if can afford) -- Rears are 5-lug, but still drum brake. Have front SN95 spindle/hub/brakes
Long Term (at in 2009+)
supercharger
"kick ass and get at least a NOPI license if not a full FD"
STL representing...poorly.
Team Drift Pirates
R32 GT-ARRRR!
Foxbody Mustang LX hatch; the new pirate drifter.
http://www.drift50.com/
i'm trying to talk my brother into getting a coupe.
B A L L I N N N ! ! 1
cool... we got a couple of fox body sliders in atlanta.
Gru
Post by Gru »
Cool!
I've actually been chatting with Dan Pena in email. He's been giving me a lot of great advice.
I'm proud to say that at least 1/3 of it has been stuff I thought of already, and he just reinforced that I'd actually been thinking right.....nice to know I'm actually learning something.
Thanks to a HORRIBLE leak, I pulled the intake manifold off. Good gasket, but previous person obviously had no clue how to properly apply sealant, as there were HUGE globs of it on all four corners that were the obvious source of the leaks.
Figured it'd be dumb not to clean the manifold since it was off and in pieces....holy crap! 19 years old, but I've never seen NEARLY that much oil and gunk buildup before. Now I know where my spare catch can is going....
Team Drift Pirates
R32 GT-ARRRR!
Gru
Post by Gru »
quazar311 wrote:cool... we got a couple of fox body sliders in atlanta.
rock on.
We had one of the dragsters up here take their Fox out on little drift area, but between the inexperienced driver and a drag suspension, it wasn't pretty.
I'm hoping to surprise St. Louis with how good a Fox can slide.
Funny how everyone is going "Oh, you'll have to do sooo much to the suspension to get it sliding right..."
But they'll turn around and say that the exact amount of changes and mods to a Corolla are "just a little work"
Other than the obvious stuff of a coilover kit, lower control arms and 2-way adjustable tie rods, the only difference to working up the solid rear axle is a torquearm bar and watts-link on the rear (which is better for drifting than the panhard bar dragsters use)
Team Drift Pirates
R32 GT-ARRRR!
quazar311 wrote:cool... Kieran O'brien is the best fox body slider in atlanta.
Gru wrote:Funny how everyone is going "Oh, you'll have to do sooo much to the suspension to get it sliding right..."
Good point!
and you can get everything you need from summit or jegs.
i wouldn't bother with getting/rebuilding a diff though. just get a spool or a mini spool and call it a day. it saves weight and will be very strong and predictable.
DJones
Post by DJones »
Gru wrote: the only difference to working up the solid rear axle is a torquearm bar and watts-link on the rear (which is better for drifting than the panhard bar dragsters use)
The panhard bar set up works pretty good for drifting too.
DJones
Post by DJones »
....domestic domination ftmfgdbasobw!!!!
Zigerus
Post by Zigerus »
Nice Gru can't wait to see it man.
Gru
Post by Gru »
P.Haire wrote:and you can get everything you need from summit or jegs.
I'm probably going to get most of the suspension stuff through Griggs Racing.
They specialize in Mustang suspension setups.
DJones wrote:The panhard bar set up works pretty good for drifting too.
From what I've read and been told (hey, Dan Pena runs a Fox in FD....I'm willing to trust his opinion), they are a little weaker on left turns than right, and they can bind on quick transitions.
Watts-link apparently has no problems with transitions. AND, it's adjustable for different tracks & conditions.
PS. Nice vid in your Sig. I'd have LOVED to get a S197 GT, but that's about 10 times the cost of my Fox.
:shock:
Zigerus wrote:Nice Gru can't wait to see it man.
Dude, I'm gonna be working on it all day tomorrow and Friday.....come on by.
Team Drift Pirates
R32 GT-ARRRR!
we thought about making a z bar for my rolla.
Sweet ride! Take it off any sweet jumps yet?
