Motor/Drivetrain:
1996 Toyota Chaser 1jz VVTi original 5 speed swap (tripod r154)
Panic Wire conversion harness
Greddy Profec B - Spec II boost controller
Summit G4851 fans and shroud
Flex-A-Lite fan controller
Billet Timing belt tensioner
OEM 2jz-gte waterpump
Gates Timing belt
Drift motion Fuel damper delete
MK4 supra TT Denso fuel pump
Jegs 6AN fuel filter
ORC 409 "hyper single"
ARP flywheel bolts
Ace Up Motorsports downpipe w/ screamer - Cermanic coated
Aspec 3 in muffler
custom 3" exhaust stainless steel
Vibrant resonator
Xcessive Manufacturing clutch pedal mount and master cylinder
Xcessive Manufacturing hydraulic hose for R154
Xcessive Manufacturing motor mounts and brackets
Xcessive Manufacturing trans mount
Xcessive Manufacturing power steering line JZ to MX
Xcessive Manufacturing Solid diff bushings
Xcessive Manufacturing Subframe reinforment plate
Xcessive Manufacturing MX83 to MK3 diff
MK3 Supra Turbo rear end
OEM Diff rebuild
Weir LSD shim kit
Shaftmasters steel one piece drive shaft
OEM mk3 supra turbo rear calipers
Interior/Exterior:
S2 cressida tail lights
Honky Enterprises gauge clock pod, radio pod
Greddy e52 boost gauge electric
Greddy e52 EGT
NRG short hub
Hoping to have it in my hands mid January.
