ladies and genlemen... i give you the "TWEEL"
http://www.sportbilen.se/e_index.php?pa ... .php?id=89
very very interesting stuff from michelin, and integrated tire/wheel setup that uses no air and performs very well, just looks a little funny ;)
Benefits of Tweelâ„¢:
The heart of Tweel innovation is its deceptively simple looking hub and spoke design that replaces the need for air pressure while delivering performance previously only available from pneumatic tires. The flexible spokes are fused with a flexible wheel that deforms to absorb shock and rebound with unimaginable ease. Without the air needed by conventional tires, Tweel still delivers pneumatic-like performance in weight-carrying capacity, ride comfort, and the ability to “envelope” road hazards.
Michelin has also found that it can tune Tweel performances independently of each other, which is a significant change from conventional tires. This means that vertical stiffness (which primarily affects ride comfort) and lateral stiffness (which affects handling and cornering) can both be optimized, pushing the performance envelope in these applications and enabling new performances not possible for current inflated tires. The Tweel prototype, demonstrated on the Audi A4, is within five percent of the rolling resistance and mass levels of current pneumatic tires. That translates to within one percent of the fuel economy of the OE fitment. Additionally, Michelin has increased the lateral stiffness by a factor of five, making the prototype unusually responsive in its handling.
Future of Tweelâ„¢ Technology:
For Michelin, Tweel is a long-term vision that represents the next step in a long path of industry-changing innovations. Fifty years ago, Michelin invented the radial tire and there is no question that radial tire technology will continue as the standard for a long time to come. Michelin continues to advance the performance of the radial tire in areas such as rolling resistance, wear life and grip. In the short-term, the lessons learned from Tweel research are being applied to improve those conventional tire performances. In the future, Tweel may reinvent the way that vehicles move. Checking tire pressure, fixing flats, highway blow-outs and balancing between traction and comfort could all fade into memory.
wow. that's certainly different, but pretty interesting.
slidewaysgolf
Post by slidewaysgolf »
They are a little ugly but it would be rad never having to worie about your tiers and what not.
Fcman
Post by Fcman »
guys i am sure they'll pust something on the outside, they probably just have them open for the demo.
Ahhhh.... The power of rotary
yeah i'm sure they will look like conventional tires when finished i think the cutaways were for demonstrations to show the inner workings.
slidewaysgolf
I wonder if they make these if they would make difernt models for preformance and regular and what no?? The could use stiffer errr thingy madoos for "racing" preformance type kinda think.
Prince Nismo
Post by Prince Nismo »
hmm, i'm skeptical. i think it's pretty cool and could offer a ton of performance and other gains but honestly what would happen if instead of people slashing tires they started filling them. i mean honestly when is the last time you got some unwanted gum in your tire. or what if people started being really cruel and put mayonaise. i mean thats just wrong. cool idea though.
Drift long
Shift Short
Boost High
Ride low
BrokeAssHachi
Post by BrokeAssHachi »
that is very interesting, i'd like to see that on the market, ill give it a shot! as long as it isnt ungodly expencive.. which it most likely will be :lol:
Silonius
Post by Silonius »
Sounds okay to me, but I do like the idea of a side covering to keep out rocks and gum and cement.
Not that I would fill someone's tire with cement.
DUDE!!! Seth... where did get the picture for your avatar?!?
That is AWESOME!!!!
Silonius
Post by Silonius »
Ha Ha! Only I shall know.
Or you can make your own at
http://www.churchsigngenerator.com
