Evelyn • My E46 Build Thread
collink
Re: BMW of DETH Build - Stunna Shades pg. 37.
Post by collink »
+1 for sitrep
DJones
Post by DJones »
revel wrote:had no idea the shop that you took your car too was at the same place my detail guy is. diamond touch detail. hush does awesome work.
yes a status update would be a good thing
No Fucking WAY!!! Hush is the MAN!!! He used to detail my car back in the day.
No go on HAL3250 shutdown. They got it where I can disable DSC with one touch of the button... instead of the secret 5-second hold-down - which is RAD. But they figured out that they couldn't eliminate ABS without prompting the same problems as pulling the fuses.
Munich suggested two things. One - take the ABS control module out, and cover the prongs that send the signal to the pump with tape. The other - put in a bad ABS control module. Matt and I are going to try the tape method 1st. Munich said they have several bad control units there if I want to try that route.
Also... on my way home from the last pizza meat - the fucking check engine light came back on. I know it is emissions-related. I can't find where my scanner is to find out though.
BOOOOOOOOOOOOOO
holy crap hush gets around! hes been taking care of my cars for the past few years and i dont plan on changing that. makes em look better than brand new!
also boooooooooo to no HAL shutdown. hopefully the tape thing works. works in my suby.
No-picture update.
For those that didn't know - the car had a catastrophic (non-motor) failure at Motorsport Nationals. While doing a massive standing burnout at the end of the FOERST 'proper' demo... it basically sounded like someone dropped a bag of marbles in the rear pumpkin. Power to the rear-end stopped immediately... and it sounded like the driveshaft was smacking the under-side of the car. Everyone helped push the car back to the pits... where we found that the driveshaft was fine... that it was probably the rear-end.
I pulled the car off the trailer today (really I let gravity do it's thing). With some help of our neighbor... Lieze and I got the car pushed into the garage. Got the car up on jackstands, and put the car in gear. The driveshaft does turn... so it really does look like it is the rear end.
We're hoping it's the ring and pinion. If it's the KAAZ... the car will be out of commission for a while.
[fingers crossed...]
I'd put my money on the ring and pinion, that's what happened to martymartymarty.net's miata. hope it's a cheap fixor. holla at me if you need some hep, I'm jobless starting tomorrow :rotate:
DJones
Post by DJones »
Yeah, I'm down to help out this weekend.
definitely the gears and not the diff.
collink
Post by collink »
andysapp wrote:No-picture update.
Fuck...good luck duder.
take the center out and bring it to me next week.
matts13 wrote:take the center out and bring it to me next week.
ANDY YOU MUST OBEY THIS COMMAND.
ive felt and heard that before
was my ring and pinion
my tomei LSD was fine
I'LL SAY IT TOO I SURE HOPE IT'S THE RING 'N' PINION DUDE!
I'll see what I can work on this weekend.
