Evelyn • My E46 Build Thread
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/p8g6tGpxbi0&hl ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/p8g6tGpxbi0&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/RmJixqlOzZ4&hl ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/RmJixqlOzZ4&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
FROM THE FOERST CUP OF TEA...
TO THE LAAAST DROP OF BLOOD...
SATAN WILL RAIN DOWN YOUR THROAT WITH HOT ACID AND DISSOLVE YOUR TESTICLES!
Time to get things rolling with the e46 to show her some love.
I snagged a free magnetic oil drain plug from UUC Motorwerks. They were celebrating their 10-year anniversary, and gave them away. I only had to pay a couple bucks for shipping.
I need to get this hydraulic e-brake setup figured out before... um... that one event coming up sometime soon eventually. That is probably going to be the next project.
We talked about it over the weekend... and I'm not sure what we decided would work the best. I'm looking at possibly doing a similar setup to Aaron Losey's 350Z with the Wilwood foot pedal assembly and seperate master cylinder.
I think this might be the one... I'm not totally sure.
new hardware is a go.
this is what you need
andysapp wrote:I think this might be the one... I'm not totally sure.
that one would work fine, just turn pedal into handle.
DJones
Post by DJones »
YES!!! to having an e-brake!!!
matts13 wrote:Image
I dunno if I want to go the CNC route or not. Can you attach a separate master to that one?
i have been thinking a jag part that may fit and would give you an worm ebrake like the stock s13. not sure how much better that would be.
that is the one with its own master cly.
That's all the fluid it needs in that reservoir? I wasn't sure if something else screwed into it.
